Dewdman42
Dec 29, 2015Virtuoso
mcrypt problem with pydio6, php5.6 on Readynas 4.x
I'm using a Readynas Ultra 2 plus with latest (and final ) firmware. I previously had pydio working fine on it. Something broke on pydio so I attempted to upgrade to the latest Pydio 6.2.1, stil...
- Dec 29, 2015
This sounds like a not 100% correctly installed PHP add-on (namely the php5-mcrypt extension) to me. Could you please try to just install the PHP 5.6 add-on again? Do not uninstall the currently installed version, just install right over it and see whether this makes the problem go away.
-Stefan
WhoCares_
Dec 29, 2015Mentor
-Stefan
- Dewdman42Dec 30, 2015Virtuoso
Thanks for the follow up!
Seems to be working now. Thanks!
