mharring54
Apr 20, 2017Aspirant
Netgear Genie update
I'm using Netgear Genie v. 2.4.10 and it keeps crashing. Trying to update but the update routine hangs on "Getting the description file..." Can't seem to find a download on the Netgear site. I use wi...
- Apr 20, 2017
Thanks. The wireshark is useful. Turns out it was my Amazon FireTV stick - problem solved. But the Netgear Genie is pretty neat for tracking network devices and referencing IP and MAC addresses. I'd like to update it and keep it from crashing everytime I open the network map.
Isn't there an easy update to download somewhere? The update from within my current version just hangs up.
jak0lantash
Apr 20, 2017Mentor
mharring54 wrote:I'm using Netgear Genie v. 2.4.10 with ReadyNAS214 and ReadyNASDuo.
Can you clarify why you're trying to use Genie with ReadyNAS? What are you trying to accomplish?
mharring54
I'm trying to troubleshoot my LAN and WLAN and the Genie is the only software I'm aware of that I have to see all the devices with IP numbers, etc. The Network Map is what keeps crashing.
I seem to have some IP conflicts and trying to figure out what they are and why. I'm not sure if I have an intruder because there is one MAC address I don't recognize.
