mfriedm1987
Jun 11, 2016Tutor
RN102 Dropbox authorization won't redirect
Hi, I just upgraded my RN102 firmware to 6.5 and went to authorize Dropbox. I toggle the switch to "On" and a new window pops up that says "Authorization... please wait" but that window just stay...
- Jun 13, 2016
Hi mfriedm1987,
Welcome to the community!
Can you confirm if other internet enabled services of your ReadyNAS works? Like Alerts (e-mail), online FW updates, Available Apps, ReadyCLOUD and etc. It is likely that your system is not connected to the internet properly. Adding Google Public DNS (8.8.8.8) and your router gateway address, would help.
Kind regards,
BrianL
NETGEAR Community Team
BrianL2
Jun 13, 2016NETGEAR Employee Retired
Hi mfriedm1987,
Kind regards,
BrianL
HIveNet
Jul 27, 2017Aspirant
I'm having this same issue and can confirm internet services are working otherwise, and Google DNSs are the only ones being used for the network connection. Any other ideas? Thank you!
