horim80
Nov 22, 2013Guide
Virtualbox on OS6 NAS
Hi all, I know that it's possible to install VirtualBox on legacy x86 NAS. What about OS6? Does anyone knows how to install VirtualBox on OS6? Thanks.
ChiffaNe
Mar 23, 2016Tutor
Followed the updated procedure and it seems everything actually worked!
sudo /sbin/rcvboxdrv setup - failed as sudo was not found but I'm not sure it actually is needed, dpkg seems to have installed everything.
ChiffaNe
Mar 23, 2016Tutor
Ok, spend the whole afternoon trying to make it work and failing.
It seems to start and work in the background, but when I try to connect via phpvirtualbox it fails, says access denied. I created the user vbox and made him a home directory, added to groub vboxusers and edited the /etc/default/virtualbox to run under him.
Also, interestingly, I can't find the /etc/init.d/vboxweb-service all of the internet is referring to.
