ErnieAlex
May 05, 2019Aspirant
Web Server does not work correctly. CSRFP-ID errors
I have the 80 Terrabyte NAS unit. (Not all drives in place.) I have one folder set up as a web server. But, my pages do not seem to render correctly. I keep getting extra code placed into the ...
ErnieAlex
May 24, 2019Aspirant
Thousands of dollars and this thing can't serve PHP out to my other local computers.... Silly waste of money!
164 views and not one response... Oh, well, will just have to sell off this unit and set up a real server here...
OOM-9
May 28, 2019NETGEAR Expert
The csrfid token information that you are seeing are security fixes that are applied to the admin interface of the ReadyNAS.
The errors that you are reported should not be related to the csrfid tokens since the configuration is set to ignore other paths on the unit.
Did you have examples where you were experiencing the issue? We were not successfull in reproducting the issue.
Further more, if you enable Secure Diagnostics Mode and PM me the 5-digit number, I can take a look from the backend to see what the issue could be.
- ErnieAlexMay 30, 2019Aspirant
This works as expected:
<!DOCTYPE html> <html> <head> </head> <body> <h3>Testing Netgear PHP page...</h3> </body> </html>
It displays the heading just fine from a LAN browser. In this case, Firefox...
BUT, this same test.php file shows all of the PHP code in read when you view the source on the browser and the PHP code does not execute. The ReadyNAS is updated to the latestest and greatest and PHP is installed and ON. It is NOT throwing the CSRFP-ID errors
at this point, but, I have not included any libraries as yet. (Such as JQuery...)
<?PHP error_reporting(E_ALL); // TEMP ! ! ! ! ! ! ! ! ! ! ! ini_set("display_errors", 1); // TEMP ! ! ! ! ! ! ! ! ! ! ! ?> <!DOCTYPE html> <html> <head> </head> <body> <h3>Testing Netgear PHP page...</h3> <?PHP echo "TESTING 1, 2, 3..."; ?> </body> </html>
So, I am guessing it is not really a CSRFP-ID error, but, something in the PHP section. I did remove and reinstall the PHP APP.
Did not help... Frustrating...
