darthy
Oct 08, 2018Apprentice
ReadyNAS 314 Length of Scrub Maintenance
Hi,
I've looked through the previous answers re how long it takes for a Scrub to complete. Most seem to point to turning off Quotas which I don't have enabled. From volume.log the Scrub took almost...
Oct 08, 2018Guru - Experienced User
What firmware are you running, and how full is the volume?
There are a lot of posts out there indicating the ST3000DM001 doesn't work well in RAID arrays. So your issue might be drive-related.
Have you checked the disk health (looking at the SMART stats in disk_info.log)? Are you seeing anything unusual in system.log or kernel.log after the scrub completes?
