kelvin_NG
Dec 02, 2024Follower
ReadyNAS 4312X Power System Alarm amber light and bizz
Recently, the 4312X start to bizz after a electricity supension, I tried to reboot the NAS, the sound still exist, then I press the mute button, the sound gone but the amber light still on. I checked the web portal, no alrm, no error log, and it function normally.
1 Reply
- SandsharkSensei
The power supplies are redundant -- it only needs one to operate. So, it sounds like either that supply is getting no power or it's defective. It's a standard supply for Chenbro servers, so easy to replace. Or you can edit the configuration file (./etc/frontview/sensors/RR4312X.conf or ./etc/frontview/sensors/RR4312XV2.conf ) to say it only has one supply. To figure out which one is appropriate to your model, see what ./etc/sensors.d/system.conf points to. You can also just remove the supply, but that could adversely affect cooling unless you block the opening with something.
- May 10, 2017Retired_Member
