RoSko
Feb 04, 2017Aspirant
ReadyNAS and Roon
Does anyone know if Roon will run on a ReadyNAS Pro? If so, how? Thanks!
- Feb 06, 2017
Hi RoSko,
Welcome to the community.
Are you referring to the Roon server?
Looking at its requirements, I do not think the ReadyNAS PRO can handle it.
They would require about 4GB or RAM and an SSD HDD for it.
Also, you can probably ask some people from Roon forums (if they have one).
FramerV
Feb 06, 2017NETGEAR Employee Retired
Hi RoSko,
- FramerVFeb 10, 2017NETGEAR Employee Retired
Hi RoSko,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards,- aalexandrebetaFeb 11, 2017Master
Interresting topic I am less stupid now :) !
- SandsharkFeb 11, 2017Sensei
Which Pro? Pro 6/BE/Pioneer CPU can be upgraded, but it has no USB3 for the SSD. I suppose you could put an SSD internal, though the trays lack the proper mounting holes and they are only SATA II. OS 6.x would be a must. Pro 2 and 4 undoubtedly lack the CPU horsepower and cannot be upgraded.
Better, I think, to run the server on a micro-PC and have it serve up music from the NAS.
