OeBe
Dec 07, 2011Aspirant
ReadyNas as a Personal Webserver
Some years ago I developped a homepage which is running properly on a Windows 2003 server as well as on a Linuxserver. I'm using perl-scripts which are accessed from a html-file. On the Readynas Duo i...
VCI_RV
Feb 10, 2012Aspirant
Did anyone ever find a resolution to this issue? I have the same issue - many of our engineer's dump nightly perl tests to the NAS. HTTP is enabled on the directory i am having issue's with, with no security what so ever (aside from initial login needed for a domain user to just access http). The Perl tests (.pl extension) are dumped to this directory - when you go to open it there is a 403 error:
Forbidden
You don't have permission to access File.pl on this server.
Forbidden
