Bill_NYC_229
Nov 24, 2018Aspirant
ReadyNAS Duo can't figure out how to install add-ons
I would like to install Minimserver on my ReadyNAS Duo, but I don't see how to install add-ons. Can anyone help me? Photo of my Raidar Home page attached.
JohnCM_S
Nov 24, 2018NETGEAR Employee Retired
Hi Bill_NYC_229,
Welcome to the Community!
If you are trying to install the add-on manually, you should be able to do it by going to System > Update then go to the Local tab. You may check page 99-100 of the software manual for the steps as well.
