Stefano0770
Dec 04, 2023Aspirant
ReadyNAS Duo V2
Buongiorno, non riesco più ad accedere alla NAS. I parametri della rete non sono cambiati, il router è sempre lo stesso. Il programma raidar (v.6.5.0) rileva correttamente la NAS e visualizzo l'i...
Stefano0770
Dec 09, 2023Aspirant
Hi Stephen;
Thank you for your reply.
I was able to access the NAS dashboard and install the add-on.
However, the NAS does not appear in File Explorer and it does not seem possible to add it as a network resource.
I am unable to access the contents of the NAS.
I tried to go to File Explorer to connect a network drive, but an error appeared.
Dec 09, 2023Guru - Experienced User
That is a different issue, and the add-on doesn't help with that.
Is SMB 1.0/CIFS enabled in the windows settings? ("turn windows features on or off").
Also, I suggest using a NAS user account instead of trying to connect with anonymous access. As a test, you can try using the NAS admin account credentials (though it is better to create a NAS user account).
