robm42
Nov 03, 2016Aspirant
ReadyNAS Factory Reset - Licenses
After I installed 6.6.0, ReadyNas Surveillance stopped working. I had many problems with this version - no apps were working for me after the 6.6.0 upgrade (including SMB and Anti-virus plugins). I...
- Nov 08, 2016
Hello robm42,
I understand the licenses have been reset and you can now reactivate them.
You may now mark the appropriate post as a solution to close this thread.
Have a great ahead!
mdgm-ntgr
Nov 03, 2016NETGEAR Employee Retired
You're supposed to deactivate the licences before doing a factory reset. Having not done this you will need to lodge a request to get the licences reset.
robm42
Thanks for the replies. I'll try sending a PM to JennC.
mdgm-ntgr Well, like I said, the application would not run any longer so I could not deactivate them or back them up. Also, when I tried to open a ticket, I was told my complimentary 90 day support has expired. I hope I don't have to buy a support contract just to get my licenses reset. :-(
-Rob
