Nowine4you
Jun 14, 2017Follower
ReadyNAS Firmware 6.7.4 ReadyNAS Surveillance run error
RN104 upgraded to firmware 6.7.4 and now ReadyNAS Surveillance returns a script <?php
include "utils.php";
session_start();
$show_in_lang = get_language_from_cookie();......and so on I paid for ...
JennC
Jun 15, 2017NETGEAR Employee Retired
Hello Nowine4you,
I checked your profile and found the case number and its update. It has been escalated and the higher tier sent you an email about trying 6.7.5-T299 (Beta 1) that has the fix.
I am not sure if you have or have not recieved it but that is the current status of the case you have opened with support team and is not closed. I suggest you try the recommendation and let us know if it resolves it or not.
Welcome to the community!
- mdgm-ntgrJun 15, 2017NETGEAR Employee Retired
There are additional fixes in ReadyNASOS 6.7.5-RC1 which is now available!
You can try this if you like or wait for the production release.
- Nov 24, 2016Retired_Member
