rcataldo
Jul 11, 2016Aspirant
ReadyNAS NV+ V2 Firmware Update: Stuck "Installing Addon"
Earlier this week I noticed that the Admin page for my ReadyNAS was no longer working (trying to open it in a browser give me a "site cannot be reached" error). I tried to start it manually using the...
rcataldo
Well, I just unplugged it and rebooted again and it seems to be working now. Strange.
BrianL2
Jul 14, 2016NETGEAR Employee Retired
Hi rcataldo,
Welcome to the community!
It is probable that your OS partition is full that's why this happened.
Kind regards,
BrianL
NETGEAR Community Team
- rcataldoJul 14, 2016Aspirant
Thanks for the reply!
Do I need to take action to fix the full OS partition? What would I need to do?
- StephenBJul 15, 2016Guru - Experienced User
You do need to fix it, a full OS partition can brick the NAS.
First check to see if it is really full. After connecting with ssh, try
df . -i
df . -h
and tell us the status.
Netgear support can also resolve it (though they will charge - ask about per-incident support).
- rcataldoJul 15, 2016Aspirant
Here's the output of the two commands:
> df . -i Filesystem Inodes IUsed IFree IUse% Mounted on /dev/md0 65536 21401 44135 33% /
> df . -h Filesystem Size Used Avail Use% Mounted on /dev/md0 4.0G 956M 2.9G 25% /
