PersianP's avatar
PersianP
Readynas Pro 6 - Err Used disks Check RAIDar
Hi everyone,
Yet again for the second time I find myself in unknown waters and issues with my unit.
I am running 6.4.2 (have been afraid of uprading) on legacy ReadyNAS Pro 6.
I was running 6x1TB drives and 1 HD broke few weeks back and I have not had time to replace.
I woke upp some days ago to an unrespsonive NAS, could not reach it
So I performed a hard reboot, keep powerbutton pushed.
After the reboot I am now confrontend with this message:
ERR: Used disks
Check Raidar
I have found previous forum post and it seem to be related to OS partition not working?
I am hoping that mdgm can once again save me please.
  • OK, so did you check RAIDar?  What did it say?  How many active drives are shown?
    Unfortunately, it sounds like you may have lost a second drive, and with it your entire volume.  The message is basically telling you it wants to create a new volume, but there is already something on the drives and you need to confirm it is OK to erase them.
    • PersianP's avatar
      PersianP
      I checked with RAIDar now and it does not show any disks.
      Said something about dirty disk and that I needed to Format a newly added disk.
      Really hope I do not lose my data volume :(
      • PersianP's avatar
        PersianP
        Wohaa I tried removing the one drive I knew was "bad", I had not taken it out before, was still in the slot during this time it had failed.
        Tried reboot with slot empty and only 5 drives and now it worked!
        Tomorrow it is time for a visit at the local PC store to buy new drives and also a backup wd passport drive :)
ProSupport for Business
