PeterS250
Feb 01, 2016Guide
Readynas remote for Android not accessing shares
I have a resadynas 204 which I can access on the local network and via Readycloud. I have installed Readynas remote 1.2.2 for Android on my phone. I can login to the readynas remote app and see all...
- Feb 03, 2016
Thank you that has given me access - and I can store what I need.
mdgm-ntgr
Feb 01, 2016NETGEAR Employee Retired
You need to install the ReadyCLOUD app for Android not ReadyNAS Remote.
BrianL2
Hi PeterS250,
In addition to mdgm's suggestion, if you want to use ReadyNAS remote, you need to enable ReadyNAS Remote Service in the admin page under the Cloud tab. Ensure the same ReadyCLOUD ID is logged in as the admin.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team
