Loekie's avatar
Loekie
Readynas remote for Android not accessing shares
I have my ReadyNASDuo v2 with RAIdIator 5.3.11 which has remote access standard, set up for a user with ftp protocol for a share (xyz). The same user is also setup for remote access. On my android i have installed ReadyNAS Remote 1.2.2 and it works up to reaching the shares. Trying to open a share results in an error: Can not connect to share (xyz) unable to login.
I have tried many things to get it working but no go. Th Nas is behind a Ziggo firewall with portforwarding for ftp port 21. The strange thing is that my Windows 10 machine is working flawless.
Any help would be appreciated.
Loekie.
  • You also need to forward passive ports.  If the router is using NAS, then masquerading might also be needed.
  • StephenB's avatar
    • Loekie's avatar
      Loekie
      Thx Stephen,
      it works now after cleaning up he root directory. There must be a max number of items this tool accepts.
      Is there a possibility to preview (would be handy for photo's)
      Thnx again for your help.
ProSupport for Business
