Loekie
May 07, 2016Aspirant
Readynas remote for Android not accessing shares
I have my ReadyNASDuo v2 with RAIdIator 5.3.11 which has remote access standard, set up for a user with ftp protocol for a share (xyz). The same user is also setup for remote access. On my android i ...
- May 07, 2016
You also need to forward passive ports. If the router is using NAS, then masquerading might also be needed.
May 07, 2016Guru - Experienced User
- LoekieMay 09, 2016Aspirant
Thx Stephen,
it works now after cleaning up he root directory. There must be a max number of items this tool accepts.
Is there a possibility to preview (would be handy for photo's)
Thnx again for your help.
