TonyStrud2
Aug 17, 2019Aspirant
ReadyNAS RN102 Can folder be set to two way sync when not on the C drive?
Is it possible to setup two way syncing when the data folders are not on the "C" drive?
Marc_V
Aug 19, 2019NETGEAR Employee Retired
Welcome to the Community!
Are you pertaining to ReadyCloud sync? or doing backup jobs on the NAS?
If you are using ReadyCloud you may want to check this link regarding backing up your folders to your ReadyNAS using ReadyCloud. You may also want to try mapping a network drive.
Setting up backup jobs will only syncs 1 way so using ReadyCloud or mapping network drive might be better.
HTH
Regards
TonyStrud2
Aug 25, 2019Aspirant
The backup function works as it should it's the sync function I was asking about as it would allow me to add files and folders from another computer when I am travelling. These added files would them automatically transfer to my main computer when it was next switched on. The backup function does not allow this as it is a one way only transfer i.e. from computer to ReadyNAS.
If my data directories were on the "C" drive this would not be a problem.
