Rollerball2021
Mar 17, 2021Aspirant
readynas RN3220 volume degraded volume resyncing
I have a readynas 3220 RNR-12A, (all 12 drives) originally I had a drive#4 showing as failed, and then drive #11 showing yellow with reallocated sectors. to be safe I did a backup to a 10 TB usb3 dr...
- Mar 17, 2021
It has to complete the re-sync of the first drive before it starts the second.
I assume you have RAID6 or RAID10, or your volume would be dead. I suggest you check the SMART stats on the one that is syncing, because it may also have issues. If it does, you may want to pull that new drive and wait for the re-sync to complete (or, possibly, fail to complete) and see if you still want to just add that new one to the others or replace the one that's currently syncing. Your volume is probably currently unprotected (depends on the RAID type), so that backup was a good fallback plan, but let's try to get you back up with a good volume and no need to restore the backup data.
Sandshark
Mar 17, 2021Sensei
Rollerball2021
Mar 19, 2021Aspirant
Well, the readynas rebuild/resynced the first bad drive, and then had a good status( backup drive only), but when it was done, it locked up and the drive was not longer there. I had to go and power th unit off and back on again, and while it was down, I replaced bad drive #4. The Nas came up and recognize drive 4- but Dark. The NAS started the rebuid/resync on # 11, whenit was done, it recognzed drive 4 and started the rebuild/resync and was going ok.
It completed and the Raid 6 shows healthy now. Shares are all accesable. what I learned form this is that it takes a long time to rebuild.
Thanks for your suggestion,. I appreciate it.
