kingmartin1976
Jan 22, 2016Aspirant
Readynas surveillance problems
Hi, So I have had my readynas 102 a few years now, only just realised I could use it with my onvif camera (I have several but I thought id get one working properly first) . I have it connected fi...
JennC
Jan 23, 2016NETGEAR Employee Retired
Hello kingmartin1976,
May I ask what version of IE and Chrome you were using to access ReadyNAS Surveillance?
.dat files are just generic info file for a specific application. If you want to save videos captured by the camera, see page 70 of the ReadyNAS Surveillance user manual.
kingmartin1976
Jan 23, 2016Aspirant
Hi. Thanks for the reply.
I am using latest version on ie and chrome. I will have a read of that manual. I couldn't find any documentation anywhere so have been working on trial and error. It is working, just only through the mobile app, which is limited compared to the full admin page on the browser. Without the video streaming working properly in the browser things are pretty useless.
- kingmartin1976Jan 23, 2016Aspirant
Hi, yes I read page 70. None of this seems to work on my browser. I think something somewhere is stopping the required plug in running. I think once the video is displayed everything else will work too.
- JennCJan 23, 2016NETGEAR Employee Retired
Can you try using lower version of IE? 8-10, I guess.
I tried to install ie9 last night but it said it's not compatible with windows 7. I imagine it won't let me downgrade to ie 10 though either.
- Nov 24, 2016Retired_Member
