banditinoz
Sep 09, 2015Apprentice
Readynas vault stopped working!
I set up ReadVAULT to copy files from dropbox back to my RN 10200 just over a week ago and it worked great. This week it doesn't work at all and it no longer allows me to use it! I did some resea...
banditinoz
Here I am thinking several people have looked at this and may reply soon,. then I find it's every time I look at it the views go up.
Surely it's not that hard to make it independant views is it?
banditinoz
Sep 12, 2015Apprentice
I've managed to get it working, I think. I'll update when I check and see if it is.
- Vault-JotiSep 14, 2015Aspirant
Hello - I'm not positive on how you setup ReadyNAS Vault to restore files from your Dropbox account onto your ReadyNAS 10200 because ReadyNAS Vault and Dropbox are two different cloud backup services and do not currently have the abililty to access files across the two services. If you can write to us at support@readynasvault.com, we'll be happy to look at your particular setup and assist.
Here is a quick test you can do to make sure your ReadyNAS has good netrowk connection: Frontview -> System -> Settings -> Update -> Check for update. No need to do any updates, but it should tell you if a update is available or if the system is up to date if it is connected to the Internet. If you get an error or no response at all, it might indicate that your device is not connected to the internet. If you have setup static IP, then DNS not having setup correctly is often the issue. Here are instructions to manually setup DNS.
- banditinozSep 21, 2015Apprentice
It wasn't working and I'd already started backing my ReadyNASup, so now I have all my data stored. I blew away my OS 6.4.0-T127 and replaced it with the T140 in the hope that'd fix it but no, lol.
So then as suggested I set up DNS manually with the ISP DNS addresses and it still didn't work, i.e. installing or uninstalling anything either. So then I added my gateway IP to the DNS list and I've had a successful install at last, Couch Potato. Haven't used CP before and don't know if it'll solve my Ready Vault issue with dropbox, but I'll keep investigating.
I got dropbox to wok with ReadyVAULT by using an ifttt recipe. Checkout ifttt.com.
Thanks for the help and I'll update after more investigating here.
N.B. I believe all my problems started when I experimented with NoIP... :-(
- Vault-JotiSep 22, 2015Aspirant
I'm still not sure which recipe you might have used from ifttt.com to get Vault to work with Dropbox. Can you please write to us at support@readynasvault.com with your account details and we'd be happy to help figure this out.
Also, did you get a chance to "check for update" for the OS? If yes, what was the result of that? Any error message, success message, or nothing at all?
