PaRau
Dec 28, 2016Follower
readynass surveillance and doorbird?
Hi,
I just installed Readynas Surveillance on my readynas Ultra 6. Nu issues there. I would like to integrate my doorbird to this system? Doorbird is connected to the same network via LAN. I can acces the HTML5 Widget and live view through ip http://192.168.x.x/bha-api/view.html (replaced some digits with x for security reasons). If I go to the readynas surveilance app and I add the camera with the correct ip, username and password I can save the camera and get the message: Updated IP Camera Setting Successfully
Obviously I cannot choose a vendor or model since the vendor isn't listed (this is probably the issue)
Live view cannot be established. I get the message: 'cannot ceate directory....'
I tried with chosing random vendors and models with the same result. Is there any way to connect the doorbird to this system? if not don't bother for the next question :-)
Also, second question. If this works I would like to expand with 3 ip camera's (2 outdoor and 1 indoor). What is the price for the licence (4 cameras) and which cameras (or brand) would you recommend. I would ike the indoor camera to be able to rotate (maby also the option to talk back) and the outdoor static but with good nightvision.
I am an absolute beginner in this area so if possible step-by-step info, thanks!
- FramerVNETGEAR Employee Retired
Hi PaRau,
I would think that the issue is with the camera's not being supported.
I have seen cases that they had issues with the camera as well as ones that do work like on this post.
You could probably try a different way of doing this. On the post above, he mentioned using zoneminder.
Unfortunately I do not have a step by step guide for it.
Hi PaRau,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
