syst3merror
Mar 05, 2015Aspirant
Remotely download torrents
Ok currently I'm using utorrent on my pc along with utorrent remote on my android phone....this allows me to login to my utorrent remotely and start files downloading even if I'm not at home on the sa...
Mar 12, 2015Guru - Experienced User
They have one Linksys, but several Netgear ones listed here: http://customer.comcast.com/help-and-su ... -adapters/. Linksys used to be Cisco-owned, but was sold to Belkin some years ago. So Cisco is no longer in the home networking business.
If you google the model number, you can usually find the manual. It will have instructions on setting up port forwarding.
Also, if the router supports address reservation (almost all do), then you should reserve a fixed local LAN IP address for the NAS. Otherwise the forwarding might break if the NAS ends up with a different local IP address.
