TonV
Sep 22, 2016Aspirant
Replicate fails with error -501
Hi all, My Replicate jobs suddenly all fail with error -501 (I can't find any info an what that means), but this is what the log in Replicate shows: Replicate version1.3.0 build R2 Starting bac...
- Sep 26, 2016
Yep, just tried that and got that working, turns out that apart from source and target settings requiring to be identical to the old job also the name of the job is critical, it has to be exactly the same as the lost job. (at the target side files are stored in a folder named after the name of the job, found that rather confusing, but anyway, once you are aware of it...)
Did that and I have my old jobs resume from where they left off, seems like I'm in business again.
Thanks for your support!
mdgm-ntgr
Sep 25, 2016NETGEAR Employee Retired
Can you try recreating the job with the same name and the same settings?
TonV
Sep 26, 2016Aspirant
