RydForLyf
May 31, 2009Tutor
Request help installing Subversion on ReadyNas Duo
I really need to get Subversion set up on my Duo, so my first question is, can this be done? Which process should I use? I have unsuccessfully tried both the Hosting Subversion service on the ReadyNAS...
Potto
May 04, 2011Aspirant
Can't locate File/Compare.pm in @INC (@INC contains: /usr/share/autoconf /etc/perl /usr/local/lib/perl/5.8.8 /usr/local/share/perl/5.8.8 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.8 /usr/share/perl/5.8 /usr/local/lib/site_perl .) at /usr/share/autoconf/Autom4te/FileUtils.pm line 136.
BEGIN failed--compilation aborted at /usr/share/autoconf/Autom4te/FileUtils.pm line 136.
Compilation failed in require at /usr/bin/autoheader line 45.
BEGIN failed--compilation aborted at /usr/bin/autoheader line 45.
I receive the same error when trying to install xdebug.
How can I install Compare.pm?
