RydForLyf
May 31, 2009Tutor
Request help installing Subversion on ReadyNas Duo
I really need to get Subversion set up on my Duo, so my first question is, can this be done? Which process should I use? I have unsuccessfully tried both the Hosting Subversion service on the ReadyNAS...
WhoCares_
Feb 06, 2013Mentor
Actually it would be easier to install packages using
-Stefan
dpkg -i <package file>instead of using the "dpkg -x" approach.
-Stefan
