neo3010
Jul 17, 2014Aspirant
RN102 + Surveillance #23535821
I installed the add-on from the add-on page, however, when I go to logon using the default credentials of admin/netgear1 it doesnt work (states its invalid). Netgear online support has been less than...
mdgm-ntgr
Aug 23, 2014NETGEAR Employee Retired
They made the same suggestion given above and neo3010 didn't follow them up asking for further suggestions.
What version of ReadyNAS OS are you running?
Do you have any other apps installed?
