neo3010
Jul 17, 2014Aspirant
RN102 + Surveillance #23535821
I installed the add-on from the add-on page, however, when I go to logon using the default credentials of admin/netgear1 it doesnt work (states its invalid). Netgear online support has been less than...
Marto731
Sep 18, 2014Aspirant
Hello,
To inform users, that the Surveillance manual has been updated, explaining this change.
http://support.netgear.com/product/RNNVR01L-1000S
Current password is " password ".
Previous versions of ReadyNAS Surveillance used the default password " netgear1 ".
If you upgrade to the latest version, and have never changed the default password, the password is changed to " password ".
