waynesam
Sep 21, 2015Follower
RN102 dropbox sync
Hi I was wondering if anyone can point me in the right direction I have a 102 with os6.2 and I can't seem to configure dropbox so as it syncs files both ways it looks like it only syncs from the 102...
JennC
Sep 23, 2015NETGEAR Employee Retired
Hello waynesam,
Please correct me if I am wrong. What you are trying to do is sync from Dropbox to your ReadyNAS?
I am able to sync both ways and either via www.dropbox.com or Dropbox app installed to the computer.
Can you give us some screenshots of the steps you do to sync from your Dropbox to the ReadyNAS?
EskenderNG
Sep 28, 2015NETGEAR Employee Retired
Hello,
Dropbox sync function used to be one way. Unfortunately, I cannot remember at which version the change took place making the sync work in both directions. However, making sure the latest firmware version is installed on your ReadyNAS would eliminate this cause for the problem.
Bye,
Eskender
