nirpal
Jun 16, 2016Follower
RN104 how to install kodi
Hi There, I a newbie to nas. I recenlty bought my first nas. A netgear readynas 104 currently running OS 6.5.0 I am looking to install Kodi onto the nas but can't find any information on how to ...
Jun 16, 2016Guru - Experienced User
Kodi is a client, not a server correct? It does have a upnp server built in, but the package as a whole really doesn't make sense on a NAS that has no Audio/Video connections.
Do you have Kodi on your players already? If so, you can just tell them to access the NAS media using NFS or SMB.
- JennCJun 16, 2016NETGEAR Employee Retired
Hello nirpal,
You may also post suggestions and ideas at the idea exchange board. Adding kudos to the ideas will help as development team will be reviewing the post that has the most kudos for considering it to add to the product's future functionality.We appreciate your contribution to the community!
- nirpalJun 17, 2016Follower
Hi StephenB,
Thanks for getting back to me. Appreciate your help.
Yes you are right now that I think about it. It is a client. Maybe I can install that on my smart TV.
Do you or anyone reading this know how to install kodi on LG Smart TV.
I can't seem to find any instructions or leads on how to install it on smart TV.
Currently my smart TV is a LG 4K smart tv running WebOS which i believe is linux based OS.
Any help would be most appreciated.
Many Thanks
Nirpal
- StephenBJun 17, 2016Guru - Experienced User
I've never tried this (I use stand-alone media players). But there are some guides out there if you google. For instance, some youtubes here: http://www.streaming1tv.com/2015/10/how-to-install-kodi-on-your-smart-tv.html
You need to scroll down past the Android stuff.
