enxer
Jul 15, 2016Aspirant
RN31200 - Installing virtualbox on ReadyNas 6.5.0
I just recently purchased a 312 and I've been following JMehring's post: https://community.netgear.com/t5/Community-Add-ons/Virtualbox-on-OS6-NAS/td-p/902756 and I get stuck on installing virtualbox ...
- Jul 23, 2016
Sorry for not getting back to you until now - I saw your post but two active kids kept me busy from repling to these threads I've made.
So I posted over in virtualbox and they reiterrated that my headers I built were not matching the running ones dispite the uname -r matching so I scraped everything, purged all modules and /usr/src and reviewed the orginal url that this author got. I pulled a similar name down that matched my readynas os 6.5.1 and made them. Additionally I added the debian repository for virtualbox wheezy and I installed dkms which monitors for kernel header changes and compiles based on the kernel modules in the system. This got me to be able to install 4.3.8 which is happily running my Windows 7 32bit (I have atom processor (non-VT-x)) running Passwordstate for the house quite well.
I hope my post helps someone out!
powareverb
Jul 23, 2016Star
Actually sorted this out in the end.
On a hunch I'd got the wrong config, I had a look around and realised there's a special config file for the readynas setup...
#Normal #sudo cp arch/x86/configs/defconfig.x86 .config #ReadyNAS sudo cp arch/x86/configs/readynas_defconfig .config
Give this a shot and see if it works. You may need to do a clean out first (of /lib/modules & kernel build dir).
Have written up a full description based on a number of great forum posts.
Kernel build:
https://gist.github.com/powareverb/5a59e4e68c7e56033ba0998ef3b53b94
VirtualBox build:
TBC
enxer
Jul 23, 2016Aspirant
