helio
Sep 23, 2021Aspirant
RN316 does no finish booting and OS install gives error "could not extracting files) last FW
Hi all, without any warnings the RN3165 stopped completing the boot at about 99%. On the first day I could login and see one fan only working. It looks the power supply fan is dead. Tried the OS r...
helio
Sep 28, 2021Aspirant
I really appreciate all you have already done :)
@StephenB, apologies if I disturb. Could I ask you to write an action plan that I could use to sort out this situation?
Thank you in advance for your input.
Sep 28, 2021Guru - Experienced User
The first step is to get into tech support mode
- boot up into tech support mode
- telnet into the NAS. Username is root and the password is infr8ntdebug
- Enter rnutil chroot (which will start RAID and chroot)
- Check the OS partition fullness by entering btrfs fi df //
Let us know the OS partition fullness by posting the output of the btrfs command here.
- helioSep 29, 2021Aspirant
Hi Steve, thank you for sending this in.
Here are the results:
# rnutil chroot
root@3C62350D01347:/# btrfs fi df //
Data, single: total=3.01GiB, used=1.44GiB
System, DUP: total=8.00MiB, used=16.00KiB
Metadata, DUP: total=497.50MiB, used=479.89MiB
GlobalReserve, single: total=240.00MiB, used=222.45MiBLet me know if you had like to see this over a Teams meeting, I would need an email to send the invitation to.
Best regards,
- StephenBSep 30, 2021Guru - Experienced User
This isn't full (used is 1.44 GiB out of 4), but I think it would be good to balance it (total allocated is 3 GiB)
This command would do that:
btrfs balance start //
It will give a warning (including a 10 second count down), but the OS partition is small, and it normally won't take very long (a minute or so).
Then I suggest trying to mount the data volume, and see if that works.
If you are using XRAID, then the commands needed are:
# btrfs device scan # btrfs fi show # mount /dev/md127 /data
Note that if this works, you can then make a backup of your data (if you don't have one).
I'm just another ReadyNAS owner, and I really can't do remote support.
- helioSep 30, 2021Aspirant
Hey Stephen,
It is not using X-Raid but Flex-Raid.
is the command the same if not, please, let me know, i stay put waiting for your reply.
Thank you.
Meanwhile the balance gave an error:
Starting balance without any filters.
ERROR: error during balancing '//': No space left on device
There may be more info in syslog - try dmesg | tail - helioSep 30, 2021Aspirant
bash: ERROR:: command not found
root@3C62350D01347:/# There may be more info in syslog - try dmesg | tail
bash: There: command not found
root@3C62350D01347:/# dmesg | tail
[ 264.060849] disk 0, o:1, dev:sdb5
[ 264.060853] disk 1, o:1, dev:sdc5
[ 264.060856] disk 2, o:1, dev:sda5
[ 264.060860] disk 3, o:1, dev:sdd5
[ 264.060864] disk 4, o:1, dev:sde5
[ 264.061090] md125: detected capacity change from 0 to 5000299151360
[ 264.081399] EXT4-fs (md0): VFS: Can't find ext4 filesystem
[ 264.081605] BTRFS: device label 0ed5edda:root devid 1 transid 2563326 /dev/md0
[ 264.082254] BTRFS info (device md0): has skinny extents
[ 304.882558] BTRFS info (device md0): 15 enospc errors during balance - StephenBSep 30, 2021Guru - Experienced User
There may be more info in syslog - try dmesg | tailTry
btrfs balance start -dusage=0 //
and see if that completes.
If it does, try increasing dusage in steps (try 50 next)
If you have a single volume, then the only thing you need to change is the volume name (/data) on the last command. That needs to be your volume name (which you specified when you created the volume).
Note that is supposed to be 6 disks of 4TB , the volume is called "data"
root@3C62350D01347:/# btrfs balance start -dusage=50 //
[ 1510.489423] BTRFS info (device md0): 4 enospc errors during balance
[ 1753.653588] BTRFS: device label 0ed5edda:data devid 3 transid 4126965 /dev/md125
[ 1753.653684] BTRFS: device label 0ed5edda:data devid 2 transid 4126965 /dev/md126
[ 1753.653768] BTRFS: device label 0ed5edda:data devid 1 transid 4126965 /dev/md127
[ 1884.973521] BTRFS info (device md0): 4 enospc errors during balance - helioSep 30, 2021Aspirant
Here the mounting results:
root@3C62350D01347:/# btrfs device scan # btrfs fi show # mount /dev/md127 /Data
Scanning for Btrfs filesystems
root@3C62350D01347:/#dmesg | tail
[ 1510.489423] BTRFS info (device md0): 4 enospc errors during balance - helioSep 30, 2021Aspirant
Hi, it did not work, still cannot see my data shares:
root@3C62350D01347:/# btrfs fi show
Label: '0ed5edda:root' uuid: ae33cd9d-ca6c-4cfa-9b1d-eec946243757
Total devices 1 FS bytes used 2.13GiB
devid 1 size 4.00GiB used 4.00GiB path /dev/md0
Label: '0ed5edda:data' uuid: cf02b0e0-e9f7-4b61-b57e-26975417ebb4
Total devices 3 FS bytes used 12.68TiB
devid 1 size 9.07TiB used 7.68TiB path /dev/md127
devid 2 size 4.55TiB used 3.15TiB path /dev/md126
devid 3 size 4.55TiB used 3.15TiB path /dev/md125
root@3C62350D01347:/# mount /dev/md127 /data
# btrfs fi df //
ERROR: not a btrfs filesystem: // - helioSep 30, 2021Aspirant
yes, it worked before.
I rebooted after running
to see if it worked.
What to do next?
How can I mount the file system back?
- SandsharkSep 30, 2021Sensei
I noticed that the metadata looks quite full:
I suspect that's why it's saying there is no remaining space, but I have no idea how it got to be so full to start with.
- StephenBOct 01, 2021Guru - Experienced User
Did you reboot normally?
If you did, reboot in tech support mode again, and repeat the steps until you get the data volume mounted. (Don't try the balance).
At that point I think you should back up all the data, and do a factory default (setting up the NAS again). We can start the SMB service if you need to back up over the network.
- helioOct 01, 2021Aspirant
HI, yesterday, I got no error after running the mount cmd so I rebooted in normal mode to see if the data was available.
since then I get the error not a btrfs filesystem
at this point all I want is to back up the date but it says
mount: mounting /dev/md127 on /Data failed: No such file or directory
# btrfs fi df //
ERROR: not a btrfs filesystem: //how to get the btrfs up again and start SMB backup?
Thanks,
StephenB Hello, Here are my last results, is it ready to start SMB backup or how to recover the data?
# rnutil chroot
devid 1 size 4.00GiB used 4.00GiB path /dev/md0Label: '0ed5edda:data' uuid: cf02b0e0-e9f7-4b61-b57e-26975417ebb4
devid 3 size 4.55TiB used 3.15TiB path /dev/md125root@3C62350D01347:/# mount /dev/md127 /data
devid 3 size 4.55TiB used 3.15TiB path /dev/md125root@3C62350D01347:/# dmesg | tail
[ 1631.881384] disk 3, o:1, dev:sdd5
[ 1631.881388] disk 4, o:1, dev:sde5
[ 1631.881622] md125: detected capacity change from 0 to 5000299151360
[ 1631.897822] EXT4-fs (md0): VFS: Can't find ext4 filesystem
[ 1631.898045] BTRFS: device label 0ed5edda:root devid 1 transid 2574192 /dev/md0
[ 1631.898746] BTRFS info (device md0): has skinny extents
[ 1711.771459] BTRFS: device label 0ed5edda:data devid 3 transid 4126974 /dev/md125
[ 1711.771548] BTRFS: device label 0ed5edda:data devid 2 transid 4126974 /dev/md126
[ 1711.771665] BTRFS: device label 0ed5edda:data devid 1 transid 4126974 /dev/md127
[ 1739.346811] BTRFS info (device md127): has skinny extents
GlobalReserve, single: total=240.00MiB, used=222.45MiBThanks :)
Yes, great, I see the shares : sorry I am slow to pick it up:
root@3C62350D01347:/# ls /data
AmazonCloudDrive DZI DropBox HdAProdz OneDrive Software Videos uFreak
Audio Documentation Freaks Music Pictures Transfer eBooks
BackUp Documents GDrive ODB Podcasts VSTIData home - helioOct 01, 2021Aspirant
StephenB , Hey, I do not have a backup of the data.
I would rather not reboot and get a SMB backup started.
I tried to start a backup from the PC but the RN316 would not accept my credentials when attempting to validate the source or could that just be the lack of SMB installed?
ok, how to backup from the support mode?
thanks
I got this:
systemctl start smb.service
Running in chroot, ignoring request. - helioOct 03, 2021Aspirant
root@3C62350D01347:/# service smb start
smb: unrecognized service
