musicwarez
Sep 10, 2017Aspirant
RND2000-200EUS Where find ADD-ONS ???
Hello, Anybody know where I can find Add-ons??? In admin web ui no available Add-ons :-( ----- RND2000-200EUS ReadyNAS DUO v2
- Sep 11, 2017
There are some here: https://kb.netgear.com/24586/RAIDiator-5-3-Add-ons
There are also some here (which are inexpensive, but not free): https://rnxtras.com/readynas-os5-arm
musicwarez
Sep 11, 2017Aspirant
OK. Thank you.
I find way to install software using apt-get when enabled ssh root access and now I think some add-ons do not need
- StephenBSep 11, 2017Guru - Experienced User
musicwarez wrote:
OK. Thank you.
Keep an eye on the OS partition use. If it grows over ~50% you should shift folders to the data volume (and put in links to them in the OS partition).
