michelefaccini
Dec 28, 2013Aspirant
Rsnapshot installed...nothing is happening...
Hi all, I've just installed this addon and commented out the following line in the addons-config/rsnapshot/rsnapshot.conf file : backup /etc/ localhost/ which should backup my etc folder to the ...
fastfwd
Dec 28, 2013Virtuoso
michelefaccini wrote: nothing is happening....
What is the output of this command?
rsnapshot configtest
What happens when you run rsnapshot in test mode with this command?
rsnapshot -t hourly
By the way, I would change three things in your configuration:
- Change "interval hourly 2" to "interval hourly 6". Rsnapshot runs the "hourly" script once every four hours to create a snapshot; you are telling it to retain only the last two of those. It would be safer to retain an entire day's worth of snapshots, and it would cost very little storage space.
- Uncomment the "rsync_short_args" line.
- Uncomment the "du_args" line.
Remember to use only tabs -- never spaces -- between elements on each line of your config file.
michelefaccini wrote: Should Rsync be activated in the frontview even if in the rsnapshot.conf file there's already this line :
# rsync must be enabled for anything to work. This is the only command that
# must be enabled.
cmd_rsync /usr/bin/rsync
I don't know whether it matters... But it couldn't hurt. It's enabled from within Frontview on my NAS.
