michelefaccini
Dec 28, 2013Aspirant
Rsnapshot installed...nothing is happening...
Hi all, I've just installed this addon and commented out the following line in the addons-config/rsnapshot/rsnapshot.conf file : backup /etc/ localhost/ which should backup my etc folder to the ...
michelefaccini
To avoid any problem, I decided to execute these kind of tests on my ReadyNas Ultra 2 Plus virtualized with VirtualBox.
I set up the rsnapshot.conf as you told me...waiting that something happens
At the following link I found this http://www.thegeekstuff.com/2010/09/rsy ... -examples/
and tried to execute the following command from PHP Shell 2.4 :
$ rsync -v /backup/config.inc.php /snapshot/config.inc.php
Obtaining the following message :
sent 892 bytes received 31 bytes 1846.00 bytes/sec
total size is 814 speedup is 0.88
rsync: mkstemp "/snapshot/.config.inc.php.lQ16RU" failed: Permission denied (13)
rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1070) [sender=3.0.9]
PS : I enabled the rsync from Frontview and put read/write privileges on the backup and snapshot share folders.
I don't understand why in the error message the file I have to copy (which is config.inc.php) has an .lQ16RU added ?
Executing the same command from the Putty shell, the task is accomplished and I obtain :
