michelefaccini
Dec 28, 2013Aspirant
Rsnapshot installed...nothing is happening...
Hi all, I've just installed this addon and commented out the following line in the addons-config/rsnapshot/rsnapshot.conf file : backup /etc/ localhost/ which should backup my etc folder to the ...
fastfwd
Dec 29, 2013Virtuoso
michelefaccini wrote: I set up the rsnapshot.conf as you told me...waiting that something happens
That is a good start. Please also try the two commands I suggested and post the output here.
michelefaccini wrote: $ rsync -v /backup/config.inc.php /snapshot/config.inc.php
Obtaining the following message :
sent 892 bytes received 31 bytes 1846.00 bytes/sec
total size is 814 speedup is 0.88
rsync: mkstemp "/snapshot/.config.inc.php.lQ16RU" failed: Permission denied (13)
rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1070) [sender=3.0.9]
PS : I enabled the rsync from Frontview and put read/write privileges on the backup and snapshot share folders.
I don't understand why in the error message the file I have to copy (which is config.inc.php) has an .lQ16RU added ?
That file is a temporary file created by rsync. The user running rsync must have read/write permissions on the folder contents and the folder itself, and if you're running rsync as root, you might need to give everyone read/write permissions on the folder and its contents.
But now I'm confused. Are you trying to backup your NAS using rsync, or rsnapshot?
