michelefaccini
Dec 28, 2013Aspirant
Rsnapshot installed...nothing is happening...
Hi all, I've just installed this addon and commented out the following line in the addons-config/rsnapshot/rsnapshot.conf file : backup /etc/ localhost/ which should backup my etc folder to the ...
fastfwd
Dec 29, 2013Virtuoso
michelefaccini wrote: Executing : rsnapshot -t hourly I get this :
rsnapshot encountered an error ! The program was invoked with these options:
/usr/local/bin/rsnapshot -t hourly
ERROR: /user/local/etc/rsnapshot.conf on line 72:
ERROR: cmd_rsnapshot_diff /usr/local/bin/rsnapshot-diff
Well, of course rsnapshot is not working: That error is preventing it from running.
Edit the /user/local/etc/rsnapshot.conf file and make sure that there is only a tab character -- no spaces! -- on that line between "cmd_rsnapshot_diff" and "/usr/local/bin/rsnapshot-diff". If you find spaces, replace them with a single tab character and then execute "rsnapshot -t hourly" again or "rsnapshot configtest".
Also, when posting text copied from the shell, it is often best to enclose the copied text between [code] and [/code] tags; that will make it easier to see whitespace properly and will ensure that the forum's formatting rules don't change the text you're copying. For example, here is a section of my rsnapshot.conf pasted without tags:
backup /c/addons-config/ localhost/
backup /c/home/ localhost/
backup /bin/ localhost/
backup /frontview/ localhost/
backup /lib/ localhost/
and here is the same section pasted between [code] and [/code] tags:
