michelefaccini
Dec 28, 2013Aspirant
Rsnapshot installed...nothing is happening...
Hi all, I've just installed this addon and commented out the following line in the addons-config/rsnapshot/rsnapshot.conf file : backup /etc/ localhost/ which should backup my etc folder to the ...
michelefaccini
Dec 31, 2013Aspirant
Still stucked with spaces instead of tabs...
Here's my current rsnapshot.conf file
Running rsnapshot -t hourly I still get the error at line 208 which says that there's a space instead of a tab between backup /lib/ and localhost/
PS: When opening a file with Komodo Edit,it's possible to specify under 'Current file settings' which kind of file you're editing...I don't know if this could matter...if yes which kind of language do I have to select ?
I tried to edit the file from the putty shell with vi.
If I try to insert a tab with ctrl-v or ctrl-I, I get V not implemented.
# rsnapshot.conf - rsnapshot configuration file #
# PLEASE BE AWARE OF THE FOLLOWING RULES: #
# This file requires tabs between elements #
# Directories require a trailing slash: #
# right: /home/ #
# wrong: /home #
# CONFIG FILE VERSION #
config_version 1.2
# SNAPSHOT ROOT DIRECTORY #
# All snapshots will be stored under this root directory.
snapshot_root /c/snapshot/
# If no_create_root is enabled, rsnapshot will not automatically create the
# snapshot_root directory. This is particularly useful if you are backing
# up to removable media, such as a FireWire or USB drive.
#no_create_root 1
# EXTERNAL PROGRAM DEPENDENCIES #
# LINUX USERS: Be sure to uncomment "cmd_cp". This gives you extra features.
# EVERYONE ELSE: Leave "cmd_cp" commented out for compatibility.
# See the README file or the man page for more details.
cmd_cp /bin/cp
# uncomment this to use the rm program instead of the built-in perl routine.
cmd_rm /bin/rm
# rsync must be enabled for anything to work. This is the only command that
# must be enabled.
cmd_rsync /usr/bin/rsync
# Uncomment this to enable remote ssh backups over rsync.
cmd_ssh /usr/bin/ssh
# Comment this out to disable syslog support.
cmd_logger /usr/bin/logger
# Uncomment this to specify the path to "du" for disk usage checks.
# If you have an older version of "du", you may also want to check the
# "du_args" parameter below.
cmd_du /usr/bin/du
# Uncomment this to specify the path to rsnapshot-diff.
cmd_rsnapshot_diff /usr/local/bin/rsnapshot-diff
# Specify the path to a script (and any optional arguments) to run right
# before rsnapshot syncs files
#cmd_preexec /path/to/preexec/script
# after rsnapshot syncs files
#cmd_postexec /path/to/postexec/script
# BACKUP INTERVALS #
# Must be unique and in ascending order #
# i.e. hourly, daily, weekly, etc. #
interval hourly 6
interval daily 7
interval weekly 4
interval monthly 3
# GLOBAL OPTIONS #
# All are optional, with sensible defaults #
# Verbose level, 1 through 5.
# 1 Quiet Print fatal errors only
# 2 Default Print errors and warnings only
# 3 Verbose Show equivalent shell commands being executed
# 4 Extra Verbose Show extra verbose information
# 5 Debug mode Everything
verbose 3
# Same as "verbose" above, but controls the amount of data sent to the
# logfile, if one is being used. The default is 3.
loglevel 3
# If you enable this, data will be written to the file you specify. The
# amount of data written is controlled by the "loglevel" parameter.
logfile /var/log/rsnapshot.log
# If enabled, rsnapshot will write a lockfile to prevent two instances
# from running simultaneously (and messing up the snapshot_root).
# If you enable this, make sure the lockfile directory is not world
# writable. Otherwise anyone can prevent the program from running.
lockfile /var/run/rsnapshot.pid
# Default rsync args. All rsync commands have at least these options set.
rsync_short_args -a
rsync_long_args --stats --delete --numeric-ids --relative --delete-excluded
# ssh has no args passed by default, but you can specify some here.
#ssh_args -p 22
# Default arguments for the "du" program (for disk space reporting).
# The GNU version of "du" is preferred. See the man page for more details.
# If your version of "du" doesn't support the -h flag, try -k flag instead.
du_args -csh
# If this is enabled, rsync won't span filesystem partitions within a
# backup point. This essentially passes the -x option to rsync.
# The default is 0 (off).
#one_fs 0
# The include and exclude parameters, if enabled, simply get passed directly
# to rsync. If you have multiple include/exclude patterns, put each one on a
# separate line. Please look up the --include and --exclude options in the
# rsync man page for more details on how to specify file name patterns.
#include ???
#include ???
#exclude ???
#exclude ???
# The include_file and exclude_file parameters, if enabled, simply get
# passed directly to rsync. Please look up the --include-from and
# --exclude-from options in the rsync man page for more details.
#include_file /path/to/include/file
#exclude_file /path/to/exclude/file
# If your version of rsync supports --link-dest, consider enable this.
# This is the best way to support special files (FIFOs, etc) cross-platform.
# Super Poussin : Do Not change link_dest Value
link_dest 1
# When sync_first is enabled, it changes the default behaviour of rsnapshot.
# Normally, when rsnapshot is called with its lowest interval
# (i.e.: "rsnapshot hourly"), it will sync files AND rotate the lowest
# intervals. With sync_first enabled, "rsnapshot sync" handles the file sync,
# and all interval calls simply rotate files. See the man page for more
# details. The default is 0 (off).
#sync_first 0
# If enabled, rsnapshot will move the oldest directory for each interval
# to [interval_name].delete, then it will remove the lockfile and delete
# that directory just before it exits. The default is 0 (off).
#use_lazy_deletes 0
# Number of rsync re-tries. If you experience any network problems or
# network card issues that tend to cause ssh to crap-out with
# "Corrupted MAC on input" errors, for example, set this to a non-zero
# value to have the rsync operation re-tried
#rsync_numtries 0
### BACKUP POINTS / SCRIPTS ###
# LOCALHOST
### ReadyNAS Users ###
### Do not use path with ###
### symlinks !! ###
### /c/media is correct ###
### /media is not correct ###
### Super Poussin ###
#backup /home/ localhost/
backup /lib/ localhost/
#backup /usr/local/ localhost/
#backup /var/log/rsnapshot localhost/
#backup /etc/passwd localhost/
#backup /home/foo/My Documents/ localhost/
#backup /foo/bar/ localhost/ one_fs=1, rsync_short_args=-urltvpog
#backup_script /usr/local/bin/backup_pgsql.sh localhost/postgres/
# EXAMPLE.COM
#backup_script /bin/date "+ backup of example.com started at %c" unused1
#backup root@example.com:/home/ example.com/ +rsync_long_args=--bwlimit=16,exclude=core
#backup root@example.com:/etc/ example.com/ exclude=mtab,exclude=core
#backup_script ssh root@example.com "mysqldump -A > /var/db/dump/mysql.sql" unused2
#backup root@example.com:/var/db/dump/ example.com/
#backup_script /bin/date "+ backup of example.com ended at %c" unused9
# CVS.SOURCEFORGE.NET
#backup_script /usr/local/bin/backup_rsnapshot_cvsroot.sh rsnapshot.cvs.sourceforge.net/
# RSYNC.SAMBA.ORG
#backup rsync://rsync.samba.org/rsyncftp/ rsync.samba.org/rsyncftp/
