michelefaccini
Dec 28, 2013Aspirant
Rsnapshot installed...nothing is happening...
Hi all, I've just installed this addon and commented out the following line in the addons-config/rsnapshot/rsnapshot.conf file : backup /etc/ localhost/ which should backup my etc folder to the ...
michelefaccini
Jan 07, 2014Aspirant
Ok....Thanks again for your answer !
Now I have to try the same test as above but with my Windows 7 Desktop PC as the destination.....
I tried this :
where Michele-pc is my Windows 7 64 bit Ultimate Desktop PC
and k:/TEST_BACKUP is a shared folder (network access to everyone)
Executing rsnapshot hourly from the putty shell, I had a whole bunch of lines....the following are the latest :
Number of files: 1668
Number of files transferred: 1045
Total file size: 3325237 bytes
Total transferred file size: 3308973 bytes
Literal data: 3308973 bytes
Matched data: 0 bytes
File list size: 55809
File list generation time: 0.001 seconds
File list transfer time: 0.000 seconds
Total bytes sent: 3411765
Total bytes received: 21998
sent 3411765 bytes received 21998 bytes 2289175.33 bytes/sec
total size is 3325237 speedup is 0.97
rsync succeeded
touch /Michele-pc/k:/test backup/hourly.0/ No directory to delete: /Michele-pc/k:/test backup/ delete.4940
rm -f /var/run/rsnapshot.pid
/usr/bin/logger -p user.info -t rsnapshot /usr/local/bin/rsnapshot hourly: \
completed successfully
BUT NOTHING IN THE DESTINATION FOLDER
I tried this :
snapshot_root /Michele-pc/k:/TEST_BACKUP/
rsync succeeded
