Digital999
Apr 06, 2022Luminary
RSYNC Failure
New Backup job -- just defined. Other jobs for the same Unit work. Fails almost instantly -- more than adequate capacity available. Any hints would be appreciated. Backup Job Name: PLEX...
- Apr 06, 2022
Did you set up the destination for write access via rsync?
Sandshark
Apr 06, 2022Sensei
- Digital999Apr 06, 2022Luminary
Thanks -- no I did not set it up for read/write.
Aside from thanks and kudos to you there , I believe, should be some change to this scenario -- better documentation, more specific error message, something.
Thanks very much.
- SandsharkApr 06, 2022Sensei
The sender has no idea why the receiver refused the transfer, and it's not unique to ReadyNAS. There could be an error log somewhere on the destination that says why. But you got it figured out, which is the main thing.
No, you got it figured out. Thanks
