hmuessig's avatar
hmuessig
Luminary
Jun 12, 2019
RSYNC failure between two ReadyNAS (?)
I've added a 524x to my system for backup (was using an EDA500 off my 716) and am using rsync to do it per the instructions in the backup FAQ.
Most of my jobs set up with the backup manager work just fine. However, two of the larger ones fail with the following message in the logs.
   Backup Job Name: HM Archives
   Backup Job Type: Full
   Protocol: rsync
   Backup Source: [HM_Archives]//
   Backup Destination: [remote:rsync]/192.168.1.29::HM_Archives
   Backup Start Time: Wed Jun 12 2019 12:16:47 PM
   Backup Finish Time: Wed Jun 12 2019 12:19:47 PM
   Backup Status: Fail: Failure during copy.
   Failed to run rsync, return rc 10
   rsync: failed to connect to 192.168.1.29 (192.168.1.29): Connection refused (111)
   rsync error: error in socket IO (code 10) at clientserver.c(127) [sender=3.1.3]
Any thoughts?
Number of files?
Drive issues (SMART stats are clean)?  But note I have 2 4TB Reds and 2 6TB Red Pros - rotation speed issues?
Thanks!
  • OK, the issue almost for sure is not using the actual IP address of the destination.
    The backup manager will allow one to search for the destination NAS and will show its name (not IP address). This can be used to complete the parameters for the backup.
    BUT as we've seen this apparently forces the NAS to periodically resolve the name and this can fail at any point in the backup.
    Too bad, because if one is using dynamic addressing on one's local network the device addresses can change if one needs to reboot the local router. And this means going through all the backup jobs and changing the address (ugh!).
    It would be simpler to resolve the name once and then store the value for the duration of the backup . . .
  • StephenB's avatar
    It shouldn't be related to number of files or certainly not rotation speed.
    The first thing to check is whether rsync is enabled for the destination share(s).
    • hmuessig's avatar
      hmuessig
      Luminary
      Thanks StephanB
      Yes, rsync (read and write) is enabled.
      Curious thing is that I can restart the backup job and it completes. And if I start the job again  - as in incremental job - it will complete again with no additional files copied.
      I have not done a full compare of the two shares to make sure everything was copied completely and correctly . . .  but am assuming that running the backup job a second time (as in incremental) checks this.
      • StephenB's avatar
        Yes.
        It might be some other resource constraint.  I've occasionally seen a failed (or stalled) rsync backup.  Re-starting it always seems to fix it.
ProSupport for Business
