chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
sirozha
Mar 09, 2009Aspirant
Chirpa,
I am glad you are trying virtualization on the Pro. I PM'ed you a couple months ago the steps I undertook to try to install VMWare server for Linux on the Pro, and the problems I ran into.
I hope you are going to try VMWare Server on the Pro soon. Please PM me if you need me to re-send the steps I took before I ran into the problem with Linux headers.
Thanks!
Thanks!
