chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
beisser1
Mar 10, 2009Tutor
for some reason the vboxdrv.ko file disappears all the time..
anyway i got a little further:
and
ReadyNAS-Pro:/lib/modules/2.6.27.6.RNx86.2.1/misc# /etc/init.d/vboxdrv start
Starting VirtualBox kernel module:
* modprobe vboxdrv failed. Please use 'dmesg' to find out why
and
vboxdrv: Trying to deactivate the NMI watchdog permanently...
vboxdrv: Successfully done.
vboxdrv: Found 2 processor cores.
vboxdrv: fAsync=0 offMin=0x1b0 offMax=0xce7
vboxdrv: TSC mode is 'synchronous', kernel timer mode is 'normal'.
vboxdrv: Successfully loaded version 2.1.4 (interface 0x000a0009).
