chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
beisser1
Mar 10, 2009Tutor
ReadyNAS-Pro:/lib/modules/2.6.27.6.RNx86.2.1/misc# VBoxHeadless -startvm "Windows2003"
WARNING: The vboxdrv kernel module is not loaded. Either there is no module
available for the current kernel (2.6.27.6.RNx86.2.1) or it failed to
load. Please recompile the kernel module and install it by
sudo /etc/init.d/vboxdrv setup
You will not be able to start VMs until this problem is fixed.
WARNING: The compilation of the vboxdrv.ko kernel module failed during the
installation for some reason. Starting a VM will not be possible.
Please consult the User Manual for build instructions.
VBoxHeadless: Error -1908 in suplibOsInit!
VBoxHeadless: VERR_VM_DRIVER_NOT_INSTALLED
VBoxHeadless: Tip! Make sure the kernel module is loaded. It may also help to reinstall VirtualBox.
hmmm :(
