chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
beisser1
Mar 10, 2009Tutor
chirpa wrote: PHP interface to VirtualBox?
that would actually rock.. an interface where you can easily create new vms, new disks or modify existing ones.
