chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
beisser1
Mar 10, 2009Tutor
super-poussin wrote: I do a quick test :
if we want an add-on will all the deb files in it , the size will be 59 MB :(
so what? its about the same size as a firmware upgrade :)
