chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
chirpa
Mar 10, 2009Luminary
super-poussin wrote: do you mean I can do a echo 'y' | apt-get install :P
Options:
-y Assume Yes to all queries and do not prompt
