chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
starg4ze
Mar 12, 2009Aspirant
dbott67 wrote: The council just released 4.2.4, but I was successful using beta T43.
http://www.readynas.com/?page_id=1004
And you followed chirpas quick install in the first post?
I'm getting quite alot of dependency-problems when running the apt-get install command:
Im running 4.2.3 release. However... if do a ls in the /lib/modules, I have a folder called 2.6.27.6.RNx86.1.1 and when I do a uname -r, I get 2.6.27.6.RNx86.1.2...something is not right here...
Nas:/lib/modules/2.6.27.6.RNx86.2.1/misc# apt-get install virtualbox-2.1
Reading package lists... Done
Building dependency tree... Done
You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
libsigc++-2.0-dev: Depends: pkg-config but it is not going to be installed
Depends: libstdc++-dev
squeezecenter-readynas: Depends: sox but it is not going to be installed
Depends: libvorbisenc2 but it is not going to be installed
Depends: libvorbisfile3 but it is not going to be installed
virtualbox-2.1: Depends: libfontconfig1 (>= 2.4.0) but it is not going to be installed
Depends: libglib2.0-0 (>= 2.12.0) but it is not going to be installed
Depends: libice6 (>= 1:1.0.0) but it is not going to be installed
Depends: libsdl1.2debian (>= 1.2.10-1) but it is not going to be installed
Depends: libsm6 but it is not going to be installed
Depends: libx11-6 but it is not going to be installed
Depends: libxcursor1 (> 1.1.2) but it is not going to be installed
Depends: libxext6 but it is not going to be installed
Depends: libxfixes3 (>= 1:4.0.1) but it is not going to be installed
Depends: libxi6 but it is not going to be installed
Depends: libxinerama1 but it is not going to be installed
Depends: libxmu6 but it is not going to be installed
Depends: libxrandr2 but it is not going to be installed
Depends: libxrender1 but it is not going to be installed
Depends: libxslt1.1 (>= 1.1.18) but it is not going to be installed
Depends: libxt6 but it is not going to be installed
Depends: python2.4 (>= 2.3.90) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
