chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
dbott67
Mar 12, 2009Guide
Here's my kernel:
Try updating to 4.2.4, as I was not successful using one of the 4.2.4 betas (T38), I think.
When I tried running the /etc/init.d/vboxdrv start command, I got an error:
chirpa then told me to try the following:
(side note: for some strange reason vboxdrv.ko was missing, so I had to re-download it)
Here's my output from SSH:
Prometheus:~# uname -r
2.6.27.6.RNx86.2.1
Prometheus:~# /etc/init.d/vboxdrv start
Starting VirtualBox kernel module:
* No suitable module for running kernel found
Prometheus:/lib/modules/2.6.27.6.RNx86.2.1/misc# insmod vboxdrv.ko
Prometheus:/lib/modules/2.6.27.6.RNx86.2.1/misc# insmod vboxnetflt.ko
Prometheus:/lib/modules/2.6.27.6.RNx86.2.1/misc# /etc/init.d/vboxdrv start
Starting VirtualBox kernel module: done.
Prometheus:/lib/modules/2.6.27.6.RNx86.2.1/misc# apt-get install virtualbox-2.1
Reading package lists... Done
Building dependency tree... Done
The following extra packages will be installed:
defoma fontconfig-config libasound2 libdirectfb-0.9-25 libfontconfig1
libglib2.0-0 libice6 libnewt0.52 libsdl1.2debian libsdl1.2debian-alsa libsm6
libsvga1 libx11-6 libx11-data libxau6 libxcursor1 libxdmcp6 libxext6
libxfixes3 libxi6 libxinerama1 libxmu6 libxrandr2 libxrender1 libxslt1.1
libxt6 python2.4 python2.4-minimal svgalibg1 ttf-dejavu whiptail x11-common
Suggested packages:
defoma-doc psfontmgr x-ttcidfont-conf dfontmgr libasound2-plugins
python2.4-doc python-profiler
Recommended packages:
libft-perl libglib2.0-data libfribidi0 libpulse0 libsdl-ttf2.0-0
linux-headers gcc make binutils libhal1 pdf-viewer libgl1
The following NEW packages will be installed:
libxt6 python2.4 python2.4-minimal svgalibg1 ttf-dejavu virtualbox-2.1
whiptail x11-common
0 upgraded, 33 newly installed, 0 to remove and 24 not upgraded.
Need to get 50.4MB of archives.
After unpacking 108MB of additional disk space will be used.
Do you want to continue [Y/n]?
Get:1 http://download.virtualbox.org etch/non-free virtualbox-2.1 2.1.4-42893_Debian_etch [38.7MB]
Get:2 http://ftp.debian.org etch/main x11-common 1:7.1.0-19 [338kB]
Get:3 http://ftp.debian.org etch/main libxau6 1:1.0.1-2 [6986B]
Get:4 http://ftp.debian.org etch/main libxdmcp6 1:1.0.1-2 [10.7kB]
Get:5 http://ftp.debian.org etch/main libx11-data 2:1.0.3-7 [157kB]
Get:6 http://ftp.debian.org etch/main libx11-6 2:1.0.3-7 [567kB]
Get:7 http://ftp.debian.org etch/main libxfixes3 1:4.0.1-5 [9304B]
Get:8 http://ftp.debian.org etch/main libice6 1:1.0.1-2 [42.6kB]
Get:9 http://ftp.debian.org etch/main libsm6 1:1.0.1-3 [18.0kB]
Get:10 http://ftp.debian.org etch/main libxt6 1:1.0.2-2 [154kB]
Get:11 http://ftp.debian.org etch/main libnewt0.52 0.52.2-10 [64.1kB]
Get:12 http://ftp.debian.org etch/main whiptail 0.52.2-10 [34.7kB]
Get:13 http://ftp.debian.org etch/main defoma 0.11.10-0.1 [100kB]
Get:14 http://ftp.debian.org etch/main ttf-dejavu 2.15-1 [3488kB]
Get:15 http://ftp.debian.org etch/main fontconfig-config 2.4.2-1.2 [149kB]
Get:16 http://ftp.debian.org etch/main libfontconfig1 2.4.2-1.2 [208kB]
Get:17 http://ftp.debian.org etch/main libglib2.0-0 2.12.4-2 [504kB]
Get:18 http://ftp.debian.org etch/main libasound2 1.0.13-2 [346kB]
Get:19 http://ftp.debian.org etch/main libdirectfb-0.9-25 0.9.25.1-5 [835kB]
Get:20 http://ftp.debian.org etch/main libsvga1 1:1.4.3-24 [311kB]
Get:21 http://ftp.debian.org etch/main svgalibg1 1:1.4.3-24 [762B]
Get:22 http://ftp.debian.org etch/main libsdl1.2debian-alsa 1.2.11-8 [209kB]
Get:23 http://ftp.debian.org etch/main libsdl1.2debian 1.2.11-8 [20.8kB]
Get:24 http://ftp.debian.org etch/main libxrender1 1:0.9.1-3 [21.1kB]
Get:25 http://ftp.debian.org etch/main libxcursor1 1.1.7-4 [23.8kB]
Get:26 http://ftp.debian.org etch/main libxext6 1:1.0.1-2 [24.6kB]
Get:27 http://ftp.debian.org etch/main libxi6 1:1.0.1-4 [16.7kB]
Get:28 http://ftp.debian.org etch/main libxinerama1 1:1.0.1-4.1 [6046B]
Get:29 http://ftp.debian.org etch/main libxmu6 1:1.0.2-2 [46.7kB]
Get:30 http://ftp.debian.org etch/main libxrandr2 2:1.1.0.2-5 [7776B]
Get:31 http://ftp.debian.org etch/main libxslt1.1 1.1.19-3 [216kB]
Get:32 http://ftp.debian.org etch/main python2.4-minimal 2.4.4-3+etch2 [902kB]
Get:33 http://ftp.debian.org etch/main python2.4 2.4.4-3+etch2 [2851kB]
Fetched 50.4MB in 3m49s (220kB/s)
debconf: delaying package configuration, since apt-utils is not installed
Selecting previously deselected package x11-common.
(Reading database ... 16682 files and directories currently installed.)
Unpacking x11-common (from .../x11-common_1%3a7.1.0-19_i386.deb) ...
Selecting previously deselected package libxau6.
Unpacking libxau6 (from .../libxau6_1%3a1.0.1-2_i386.deb) ...
Selecting previously deselected package libxdmcp6.
Unpacking libxdmcp6 (from .../libxdmcp6_1%3a1.0.1-2_i386.deb) ...
Setting up x11-common (7.1.0-19) ...
Selecting previously deselected package libx11-data.
(Reading database ... 16727 files and directories currently installed.)
Unpacking libx11-data (from .../libx11-data_2%3a1.0.3-7_all.deb) ...
Selecting previously deselected package libx11-6.
Unpacking libx11-6 (from .../libx11-6_2%3a1.0.3-7_i386.deb) ...
Selecting previously deselected package libxfixes3.
Unpacking libxfixes3 (from .../libxfixes3_1%3a4.0.1-5_i386.deb) ...
Selecting previously deselected package libice6.
Unpacking libice6 (from .../libice6_1%3a1.0.1-2_i386.deb) ...
Selecting previously deselected package libsm6.
Unpacking libsm6 (from .../libsm6_1%3a1.0.1-3_i386.deb) ...
Selecting previously deselected package libxt6.
Unpacking libxt6 (from .../libxt6_1%3a1.0.2-2_i386.deb) ...
Selecting previously deselected package libnewt0.52.
Unpacking libnewt0.52 (from .../libnewt0.52_0.52.2-10_i386.deb) ...
Selecting previously deselected package whiptail.
Unpacking whiptail (from .../whiptail_0.52.2-10_i386.deb) ...
Selecting previously deselected package defoma.
Unpacking defoma (from .../defoma_0.11.10-0.1_all.deb) ...
Selecting previously deselected package ttf-dejavu.
Unpacking ttf-dejavu (from .../ttf-dejavu_2.15-1_all.deb) ...
Selecting previously deselected package fontconfig-config.
Unpacking fontconfig-config (from .../fontconfig-config_2.4.2-1.2_all.deb) ...
Selecting previously deselected package libfontconfig1.
Unpacking libfontconfig1 (from .../libfontconfig1_2.4.2-1.2_i386.deb) ...
Selecting previously deselected package libglib2.0-0.
Unpacking libglib2.0-0 (from .../libglib2.0-0_2.12.4-2_i386.deb) ...
Selecting previously deselected package libasound2.
Unpacking libasound2 (from .../libasound2_1.0.13-2_i386.deb) ...
Selecting previously deselected package libdirectfb-0.9-25.
Unpacking libdirectfb-0.9-25 (from .../libdirectfb-0.9-25_0.9.25.1-5_i386.deb) ...
Selecting previously deselected package libsvga1.
Unpacking libsvga1 (from .../libsvga1_1%3a1.4.3-24_i386.deb) ...
Selecting previously deselected package svgalibg1.
Unpacking svgalibg1 (from .../svgalibg1_1%3a1.4.3-24_all.deb) ...
Selecting previously deselected package libsdl1.2debian-alsa.
Unpacking libsdl1.2debian-alsa (from .../libsdl1.2debian-alsa_1.2.11-8_i386.deb) ...
Selecting previously deselected package libsdl1.2debian.
Unpacking libsdl1.2debian (from .../libsdl1.2debian_1.2.11-8_i386.deb) ...
Selecting previously deselected package libxrender1.
Unpacking libxrender1 (from .../libxrender1_1%3a0.9.1-3_i386.deb) ...
Selecting previously deselected package libxcursor1.
Unpacking libxcursor1 (from .../libxcursor1_1.1.7-4_i386.deb) ...
Selecting previously deselected package libxext6.
Unpacking libxext6 (from .../libxext6_1%3a1.0.1-2_i386.deb) ...
Selecting previously deselected package libxi6.
Unpacking libxi6 (from .../libxi6_1%3a1.0.1-4_i386.deb) ...
Selecting previously deselected package libxinerama1.
Unpacking libxinerama1 (from .../libxinerama1_1%3a1.0.1-4.1_i386.deb) ...
Selecting previously deselected package libxmu6.
Unpacking libxmu6 (from .../libxmu6_1%3a1.0.2-2_i386.deb) ...
Selecting previously deselected package libxrandr2.
Unpacking libxrandr2 (from .../libxrandr2_2%3a1.1.0.2-5_i386.deb) ...
Selecting previously deselected package libxslt1.1.
Unpacking libxslt1.1 (from .../libxslt1.1_1.1.19-3_i386.deb) ...
Selecting previously deselected package python2.4-minimal.
Unpacking python2.4-minimal (from .../python2.4-minimal_2.4.4-3+etch2_i386.deb) ...
Selecting previously deselected package python2.4.
Unpacking python2.4 (from .../python2.4_2.4.4-3+etch2_i386.deb) ...
Selecting previously deselected package virtualbox-2.1.
Unpacking virtualbox-2.1 (from .../virtualbox-2.1_2.1.4-42893%5fDebian%5fetch_i386.deb) ...
Setting up libxau6 (1.0.1-2) ...
Setting up libxdmcp6 (1.0.1-2) ...
Setting up libx11-data (1.0.3-7) ...
Setting up libx11-6 (1.0.3-7) ...
Setting up libxfixes3 (4.0.1-5) ...
Setting up libice6 (1.0.1-2) ...
Setting up libsm6 (1.0.1-3) ...
Setting up libxt6 (1.0.2-2) ...
Setting up libnewt0.52 (0.52.2-10) ...
Setting up whiptail (0.52.2-10) ...
Setting up defoma (0.11.10-0.1) ...
Setting up ttf-dejavu (2.15-1) ...
Setting up fontconfig-config (2.4.2-1.2) ...
Setting up libfontconfig1 (2.4.2-1.2) ...
Setting up libglib2.0-0 (2.12.4-2) ...
Setting up libasound2 (1.0.13-2) ...
Setting up libdirectfb-0.9-25 (0.9.25.1-5) ...
Setting up libsvga1 (1.4.3-24) ...
Setting up svgalibg1 (1.4.3-24) ...
Setting up libsdl1.2debian-alsa (1.2.11-8) ...
Setting up libsdl1.2debian (1.2.11-8) ...
Setting up libxrender1 (0.9.1-3) ...
Setting up libxcursor1 (1.1.7-4) ...
Setting up libxext6 (1.0.1-2) ...
Setting up libxi6 (1.0.1-4) ...
Setting up libxinerama1 (1.0.1-4.1) ...
Setting up libxmu6 (1.0.2-2) ...
Setting up libxrandr2 (1.1.0.2-5) ...
Setting up libxslt1.1 (1.1.19-3) ...
Setting up python2.4-minimal (2.4.4-3+etch2) ...
Linking and byte-compiling packages for runtime python2.4...
Setting up python2.4 (2.4.4-3+etch2) ...
Setting up virtualbox-2.1 (2.1.4-42893_Debian_etch) ...
Adding group `vboxusers' (GID 101) ...
Done.
Messages emitted during module compilation will be logged to /var/log/vbox-install.log.
